LED dome lights problem
Old Nov 16, 2011 | 02:03 AM
thunderhemi's Avatar
thunderhemi
Default LED dome lights problem
hey guys I recently installed some led dome light bulbs into my 07 ram and ran into an issue. When the key is not in the ignition and you open the door the lights flicker like a strobe. But when the truck is on everything works just fine. Could it not be getting enough power? or maybe im using a wrong bulb? any ideas would help!
Old Nov 16, 2011 | 07:36 AM
theice's Avatar
theice
you have to put a resister across both wires for each dome light run it from the pos to the neg and it will solve your problem
