03 ram Shacking
Old Nov 21, 2011 | 05:29 PM
02_RAMMING's Avatar
02_RAMMING
Default 03 ram Shacking
Hi i have a 03 ram 1500 4x4 sport i just changed the heater core over the weekend and now when idleing or driving the truck shacks ides out fine when i give it gas but when i let up its back any help where to start
Old Nov 21, 2011 | 07:17 PM
02_RAMMING's Avatar
02_RAMMING
Also notice truck lacks power and at idle when i take foot off brake truck like hesitates moving
Old Nov 21, 2011 | 07:23 PM
drewactual's Avatar
drewactual
coolant is H E L L on o2 sensors.. if you spilled a significant amount directly on one, it could render it useless..
that's a little bit of info worth sharing.. but, likely not your issue.. your issue is most likely that you have a vacuum leak...
get yourself a can of TB cleaner aerosol.. spray carefully around the firewall of the truck.. when you hear the idle change, you've found the area your leak.. of course, it could be an easy one, and you may simply see a hose dangling somewhere.. start at the manifold and work downstream..
Last edited by drewactual; Nov 21, 2011 at 07:26 PM. Reason: I'm a non spelling rascal..
