The Hemi: worse gas mileage in cold weather?
Old Nov 22, 2011 | 08:52 AM
Whiskey20's Avatar
Whiskey20
My 07 1500 always drops in the winter, I have always attributed it warm up times where the truck sits idoling as well as the increased ethonol in the gas. I was expecting a bigger drop when I turned the MDS off, but that didn't effect the millage that badly. However, I was running about 13.3 MPG this summer, (Mostly city 70% or so) I live in North Dakota and am dropping quickly, I'm down to 10.1 MPG or so. If last winter was any indication, I'll be down to near 8... :-/
Old Nov 22, 2011 | 10:05 AM
scwpd's Avatar
scwpd
I think nolimit was referring to star tron I believe hammer or someone on here posted something about it a while back I just got some yesterday to see how well it works for myself I'll post back after a while and let you know
Old Nov 22, 2011 | 11:49 AM
HammerZ71's Avatar
HammerZ71
I would gather... I run it religiously now, started just using it in my lawn equipment/small engine stuff because I was getting tired of dealing with replacing primer bulbs, fuel lines and doing carb work on the seldom used things I have. It was recommended by a friend with a Lawn Care/Landscaping business. It has done wonders in my small engines and I started using it in ALL my gas about six or eight weeks ago. On about the 3rd tankful of gas I could notice a smoother idle and a small increase in fuel economy. I'm sold on the stuff and now buy it in a super concentrate bottle (8 oz. bottle treats 128 gallons of gas) and get the lower concentrate for the lawn stuff and my ATV (8 oz. bottle treats 48 gallons) just because it's easier to measure in my small (1, 2.5 and 5 gallon) fuel containers. It's much more economical to buy the super concentrate for vehicle use.
I'm down to one gas station in my area that sells non-ethanol gas and he doesn't take credit cards. At the price of fuel anymore and the size of my tanks, I just don't regularly carry enough cash to fill up my vehicles and it's a PIA to remember to hit the bank or ATM (plus my bank just started charging for ATM withdrawals - even at their branches. Now it's no big deal, I just use the StarTron and I'm getting the same results as when I was buying non-ethanol gas...
Old Nov 22, 2011 | 10:34 PM
olyelr's Avatar
olyelr
Originally Posted by rammaster
Another question i have is right now for wheels i have 20 inch xd badlands and they dont even clear the caliper by an inch. how were the stock rims 17 inches? unless these wheels are just extra thick
My stock 17's clear the calipers by a very small amount. Without measuring (going by memory), I would be guessing 3/8 of an inch or so. So at best, your 20's may be 1 1/2" further away, but they are probably thicker so most likely even less than that.
Old Nov 22, 2011 | 11:09 PM
NoLimitzR1's Avatar
NoLimitzR1
I stand corrected startron, so much reading on here I lose track of little details
Old Nov 22, 2011 | 11:40 PM
Magnum4406's Avatar
Magnum4406
Don't forget all the fluids are thicker in the cold, diff's, wheel bearings. engine, etc. That also causes more drag until they get up to temp.
Old Nov 23, 2011 | 02:30 PM
rammaster's Avatar
rammaster
I actually do use star tron in all my lawn equipment and in my boat gas. I never thought of using it in the truck. So it is safe?
Old Nov 23, 2011 | 02:46 PM
HammerZ71's Avatar
HammerZ71
Good for ALL 2 and 4 cycle engines...
Old Nov 23, 2011 | 11:36 PM
truckin151's Avatar
truckin151
There are a few factors that come into play here. Each one hurting your fuel economy a little and when added up, the result can be major. Most have already been touched on in this thread.
First of all, by early November we are all getting "winter blend" fuel. The winter mix has a higher Reid Vapor Pressure which results in slightly less energy per volume of gasoline. In other words, you have to burn a little more of it to get the same results as with "summer gas".
Temperatures are decreasing, lower temperature air is more dense and the more dense the air is, the more fuel must be mixed with it to yield the same air/fuel ratio.
A CAI lets in more air volume simply due to the increased surface area of a cone filter vs. a flat filter. More air = more fuel needed, more COLDER air means that much more.
Air pressure in tires decreases as air temperature decreases. Running on lower air pressure results in greater road surface resistance which yields lower fuel economy.
20" wheels are significantly heavier than 17" wheels requiring more energy to move them. Energy overhead is higher in colder weather than warmer due to all of the factors I've listed. If you need a certain amount of energy to move your truck in 80* temps, you will require more energy to move it in 40* temps...
Bad mpg's aside though.... all this equals a fun time to drive, quicker ET's lower DA, its the best time of the year to run. I'll take the hit in mpg's to get it to run so much better but thats just me...
