Tried the Key trick to pull codes
Hey Guys,
I tried the key trick to pull p codes as I have some c codes and wanted to try to pinpoint any issues I may be having and not even know. Anyway, for some reason it is not working at all for me, but my main question is...before doing this, I could have SWORN that when I opened my door after turning the engine off, all the doors unlocked at the same time...and now they are not. Maybe I am just going crazy, and it really didn't do this, can anyone shine some light on this issue? Also I'm pretty sure the dome lights stayed on a lot longer than they do now, is any of this pertainant to my attempt of the key trick??
I tried the same thing also. I managed to pull up the error codes, but ever since then, the CD changer goes into eject mode and switches through all 6. This continues until I turn on/off the unit. As for the dome lights, they stay on much longer after exiting the vehicle, as long as 10 minutes. I've taken to turning on/off/on the alarm to turn them off quicker. In the future, I'll just have Autozone pull the codes for me. They do it for no charge in my area.
On my '03, if you open the driver's door while the motor is running, only the driver's door unlocks. If you shut it off first, all the doors unlock. If a passenger opens a door before the driver's door is opened then opening the driver's door does NOT unlock all the other doors.
Your '06 probably has more variables to set. My '06 Chrysler has way more options for this kind of thing. You can probably set how long the head lights stay on, how long the dome lights stay on, etc., etc.
Sorry, I'm hoping I have the terminologies correct, but right now I've had a few adult soda's and a huge argument, so frankly may not be thinking clearly...but I KNOW I have the right ideas somewhere in my head whether it is coming out properly through my finger tips or not
