Reverse light wire location
Old Nov 30, 2011 | 09:40 PM
evomega08's Avatar
evomega08
Default Reverse light wire location
I would like to install some reverse lights on my truck and my trailer, I know the 7 pin harness already has power for this but I would like to turn them on by switch. Can anyone tell me where to find the wire under the hood and what color it would be.
Old Dec 1, 2011 | 12:29 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
reverse is white with a light green stripe under the hood on the pass side firewall coming out of one of the harness plugs on the PCM
Test by having the truck in P and checking for 12v (should be 0v) and then either having someone help you or chock the wheel and set the parking brake and putting the truck in R and checking the wire again (should be 12v+)
