HELP PLEASE, Transmission problems? Scanner codes inside...
2005 Dodge Ram 1500 quad cab, 2 wheel drive, automatic, 4.7L, 97k miles.
Anyways, its never shifted funny or anything until this, I drove it to work fine and parked it. I came out from work and started it, put it in drive and it didn't go in gear. Then it dropped into gear and the check engine light is on. When driving it seemed like it was starting from a higher gear like 2nd or 3rd. I turned it off and back on and it shifts fine again. I scanned it and it gave 3 codes:
P0700- Trans Control Sys Malfunction
P0731- Gear 1 Ratio Incorrect
P0876- Trans Fluid Press Sensor/Switch D CKT Range/Perf
What am I looking at?! Anyone with experience on this?
