over flow bottle and efans question
Old Dec 21, 2011 | 11:55 PM
Peter sask's Avatar
Peter sask
Flex a Lite comes with bracket for stock overflow tank and an adjustable temperature sensor with a/c relayto operatethe fan between 160 and 240 degrees.(quoted from an ad in Lifted Wrenched and Raised mag.)
Old Dec 22, 2011 | 02:56 AM
Manvin's Avatar
Manvin
i was looking at getting efans for the extra power it frees up, but i am jut wondering how hard they are to install. my buddy got his dad and a friend to install his on a 07 F-15 and he said it took them 10 hrs to do.
Old Dec 22, 2011 | 07:01 AM
MikeHTally's Avatar
MikeHTally
Mine went on in less than two hours. I retained the stock shroud. As for installing on an F-15, I can see that taking a while. Wonder if the Air Force has a kit?
Old Dec 22, 2011 | 07:30 AM
HammerZ71's Avatar
HammerZ71
Then your buddy's dad and his friend are f*cking useless, about two hours to install mine in the driveway by myself and prior to that I had never installed one before and that included building a tool out of a 2x4 and bolt to remove the stock fan...
Old Dec 22, 2011 | 10:40 AM
scwpd's Avatar
scwpd
Only took me a a friend a couple hours we didn't use the brackets it came with just used some aluminum bar and made our own and drilled into the rad and used some bolts with nylock nuts and put the shroud back over that
Old Dec 22, 2011 | 10:00 PM
Manvin's Avatar
Manvin
ok that is good to hear. I was apprehensive to swap it out. But if it only takes a few hours and isnt incredibly hard to do, i think ill have a go
