Got my intune tuner, mediocre results so far
Old Dec 21, 2011 | 09:51 PM
NoLimitzR1's Avatar
NoLimitzR1
Default Got my intune tuner, mediocre results so far
Just got my diablosport intune programmer, and wondering if anyone else has and used on a 3rd gen. I seem to br having issues, unit updated when i go to tune I have only tcm tuning options, nothing else no tunes for the pcm, if my truck was previously flashed with a programmer do you think this would be why? The programmer so new that even forums are little help yet, tech support had me do a force calibration but no dice yet. Although I will say I flashed the tcm tune and was pleased with the shift points and holding gears longer in my case is what I needed to avoid more shifts, wear and tear, and get my mpg up, I can say so far that I track my mpg carefully by hand, i use same driving habits daily and I noticing .5 mpg increase by getting my tranny under control
, although new gears is the proper solution the tuning helps for my situation based on the roads and hills I use to commute on. Any questions about unit itself I'm hear to answer, i just cant tell you the pcm tuning side yet. i am thinking of a dealer pcm flash to be sure its not the cause.
Old Dec 22, 2011 | 02:16 PM
NoLimitzR1's Avatar
NoLimitzR1
Update- spoke with Frank at tech support a ticket has been made for engineering, apparently the calid is not in the system they are making it in next update, preliminary eta is at least a week or so, forgot off top of my head the calid but ends in AH, if you have one and having issues or its working please let me know
