Where to get custom leaf springs for Lift
Old Dec 28, 2011 | 03:40 PM
meltorres's Avatar
meltorres
Default Where to get custom leaf springs for Lift
I am planning on buying the one inch Daystar spacer for my 2006 Dodge 1500 2WD. I currently have the 7" CST lift and a 3" Body lift. However when I get the spacer in the front I do not want to get a 4"+ block. Instead I was hoping there was someway to get some aftermarket leaf springs for the truck. I cannot stand the block look. Let me know if you know of where I could get something like this done, as well as how much I'm looking at to do something like that.
Thanks,
Ethan
Old Dec 29, 2011 | 03:19 AM
Brandon Anderson's Avatar
Brandon Anderson
CST makes a 6" inch kit that is 4" spindles and 2" spacers for the front. For 7" of lift, that's the 4" spindles then the 3" body lift, meaning your rear is currently only blocked maybe an inch. I'm sorry it isn't a direct answer to your question, but FYI just to make sure you don't jump into custom leaf springs if you don't have to. You could easily get away with a 2" block and a set of 2nd gen drop shackles to keep your truck leveled. Good luck!
