Installing gauges
Old Jan 11, 2012 | 05:17 AM
03whiteram's Avatar
03whiteram
Arrow Installing gauges
I have an 03 Ram 4.7. I am looking to install a coolant temp gauge, oil pressure gauge, and oil pressure gauge. Does anyone have any info/instructions on how and what other parts are needed to complete these installations?
Old Jan 11, 2012 | 08:47 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
The coolant temp you will need to tap on of the wires on the coolant temp sensor. Im sure you mistyped it but you say you have two oil press gauges.
Either way, how you connect those depend on what type of gauge it is, electrical or mechanical.
Old Jan 11, 2012 | 12:42 PM
03whiteram's Avatar
03whiteram
I am planning on using the autometer ultralite II gauge.
Old Jan 11, 2012 | 12:46 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
im on my mobile so that still doesnt help.
If its electrical then you tap into the electrical wiring on the sensor which is right above the oil filter. If its mechanical then you need to add a fitting to screw your gauge piece into.
You read your instructions with the gauges right?
What part are you confused on? Where they install or how?
Old Jan 11, 2012 | 01:05 PM
03whiteram's Avatar
03whiteram
I don't have them yet. Still deployed. But the gauges I am planning to install are electrical for the oil pressure and temperature.
Old Jan 11, 2012 | 01:17 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Then all you likely will have are three wires for each. One for ground, one for 12v for the backlight and the last to tap the sensor wire with.
Since you dont have them, check the manufactures site for instructions but that should be how they go. The oil press sensor is a two wire sensor and above the oil filter. The water temp sensor is also two wires and located either in the block or on the stat housing.
Old Jan 11, 2012 | 01:25 PM
03whiteram's Avatar
03whiteram
Thanks for your help.
Old Jan 11, 2012 | 04:04 PM
boosted-fc3s's Avatar
boosted-fc3s
Wouldn't it be better/more accurate to use an autometer electric watertemp sensor? When I added gauges to my turbo rx7 I added an electric water temp sensor to bypass the crappy stock sensor.
Old Jan 12, 2012 | 01:49 PM
03whiteram's Avatar
03whiteram
The coolant temp sensor is electrical...
