Magnaflow Y and Muffler sizes
Old Jan 25, 2012 | 06:44 PM
bball14's Avatar
bball14
Default Magnaflow Y and Muffler sizes
I have an 07 Quad Cab 4x4 with a 4.7l. I want to get rid of the stock muffler and resonator and replace it with an 18" magnaflow and Y-pipe. My question is what sizes for the inlets and outlets do I neet and what offsets are needed on the inlets and outlets?
I plan on keeping the stock exhaust look, with the single tail pipe exiting behind the rear wheel. Thanks.
Old Jan 26, 2012 | 01:21 PM
bball14's Avatar
bball14
To the top...been using the search and haven't found the answer yet.
Old Jan 26, 2012 | 01:48 PM
Brandon Anderson's Avatar
Brandon Anderson
For best performance, I would take out the "Y" completely and run the 2.5" pipe from the cats all the way to a DI/DO muffler (or DI/SO if you are set on single exit). To directly answer your question, the pipes out of the cats are about 2.5 inches, so a "Y" with 2.5" in and 3" out would work fine for you. Offset on the muffler really does not matter.
