engine light
Old Jan 26, 2012 | 04:53 PM
ramsa1604's Avatar
ramsa1604
Unhappy engine light
My engine light came on while ideling.I took it to a parts house to check the code.It said low oil pressure . I checked my oil level it was fine also my oil gauge was fine as well. This problem started after changing my oil. I did use the correct oil. Please help with problem.Thanks Frank
Old Jan 26, 2012 | 06:58 PM
MikeHTally's Avatar
MikeHTally
What motor? How many miles? How much oil did you use? The oil "gauge" is little more than an idiot light with a needle.
Old Jan 26, 2012 | 09:05 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
As long as the oil level in fine I would replace the oil press sensor and go from there.
