2006 ram 1500 lonestar?
Old Jan 29, 2012 | 08:03 PM
kyleenright's Avatar
kyleenright
Default 2006 ram 1500 lonestar?
Looking at a 2006 Dodge Ram 1500. Has a lonestar badge on drivers side door. Serial #1D7HU18266S59045. Is there anyone that can disect this serial number to tell me what I have here? Truck only has 43000 kilometers.
Thanks
Old Jan 29, 2012 | 08:53 PM
Owensue's Avatar
Owensue
That's an invalid vin, there should be 17 digits in the vin.
Have another look
Use this list to get basic info, or lookup he option codes for this truck if you have access.
What does my vin mean you ask? Decode it here....
POSITION INTERPRETATION CODE = DESCRIPTION
1 Country of Origin 1 = Manufactured By DaimlerChrysler Corporation
..........................3 = Manufactured By DaimlerChrysler De Mexico
2 Make D = Dodge
3 Vehicle Type 2 = Incomplete with Side Airbag
.....................3 = Truck with Side Airbag
.....................6 = Incomplete Less Side Airbag
.....................7 = Truck Less Side Airbag
4 Gross Vehicle Weight Rating G = 5,001-6000 lbs.
........................................H = 6,001-7,000 lbs.
........................................J = 7,001-8,000 lbs.
........................................K = 8,001-9,000 lbs.
........................................L = 9,001-10,000 lbs.
........................................M = 10,001-14,000 lbs.
........................................W = Buses/Incomplete Vehicles with Hydraulic Brakes
5 Vehicle Line A = Ram Pickup 4X2
...................U = Ram Pickup 4X4
...................N = Ram Pickup 4X2 DX Family
6 Series 1 = 1500
............2 = 2500
............3 = 3500 Less Dual Rear Wheels
............4 = 3500 With Dual Rear Wheels
............5 = 4000 DX Family
7 Body Style 6 = Conventional Cab/Cab Chassis
..................8 = Quad Cab Full Rear Doors
8 Engine K = 3.7L 6 cyl. MPI Gasoline
............N = 4.7L 8 cyl. MPI Gasoline
............D = 5.7L 8 cyl. SMPI Gasoline
............6 = 5.9L 6 cyl. Turbo Diesel 24v
............C = 5.9L 6 cyl. Turbo Diesel High Output
9 Check Digit 0 through 9 or X
10 Model Year 4 = 2004
11 Plant Location S = Dodge City
........................G = Saltillo
........................J = St. Louis (North)
12 thru 17 Vehicle Build Sequence
Old Jan 29, 2012 | 09:16 PM
kyleenright
sorry complete vin#1D7HU18266S590405
Old Jan 29, 2012 | 09:43 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You can also find that info in the service manuals located in the links in my sig. Every new member should get a copy
Old Jan 30, 2012 | 01:51 AM
HemiLonestar's Avatar
HemiLonestar
Also in the parts manuals.
