Fog lights
Old Feb 6, 2012 | 02:00 PM
LiftedMegaCab Ram's Avatar
LiftedMegaCab Ram
Default Fog lights
I have a 2006 Ram 5.7l, I would like for the fog lights to be on as well as the low beams is this possible? I have read a lot and it seems that the dealer just has to turn them on is this correct?
Any help would be appreciated.
Old Feb 6, 2012 | 06:04 PM
MoparPaul's Avatar
MoparPaul
I used this and it works great:
http://www.ebay.com/itm/02-08-10-11-...76467948443650
Old Feb 6, 2012 | 06:33 PM
Bent's Avatar
Bent
any chance you have a diagram of how that kit hooked up?
Old Feb 7, 2012 | 11:06 AM
NV290's Avatar
NV290
I have used one of these Bright Boxes on both my Rams. Pricey, but so simple to hook up with no wires to cut or splice so no chance of making a costly mistake and no chance of failed splices over time and installing it and removing it is a breeze:
http://www.genosgarage.com/prodinfo....ber=BB-SDK8FLC
It will keep your low beams on with your brights AND keep your fog lights on.
Old Feb 7, 2012 | 04:10 PM
Wanderer's Avatar
Wanderer
I have a 2004 and I can have the fogs on with low beams. Do you mean with the high beams? If so, there are many threads with pictures and diagrams.
Old Feb 7, 2012 | 07:37 PM
HammerZ71's Avatar
HammerZ71
You're not gonna be able to pull off the simple wire trick on a '06+ TIPM truck. I have installed the Bright Box on a 2008 with no problem. That $25 deal has peaked my interest though...
