Torsion bars
Old Feb 7, 2012 | 12:09 AM
PolarJay's Avatar
PolarJay
Default Torsion bars
I have a 2004 QC 1500 4x4. How do you properly adjust the torsion bars? Does the truck need to be on a lift? Or, can you simply adjust the bars on the ground?
Old Feb 7, 2012 | 12:47 AM
NoLimitzR1's Avatar
NoLimitzR1
Lift thw front off the ground. Don't try cranking with weight of truck on the bars. Bolt will likely snap. Search for torsion bar crank. Sure there's a video or tutorial online
Old Feb 7, 2012 | 12:51 AM
PolarJay's Avatar
PolarJay
Thanks Nolimitz. Appreciate the advice.
Old Feb 7, 2012 | 01:05 AM
Owensue's Avatar
Owensue
There is a video here, skip the removal and just do the cranking part.
https://dodgeforum.com/forum/3rd-gen...s-install.html
Basically as mentioned, you want to unload the suspension while cranking it up, also you will need an alignment and headlamp adjust as it states in the video.
Old Feb 8, 2012 | 02:34 PM
04HemiGreg's Avatar
04HemiGreg
The video Owensue posted a link to shows a leveling kit being installed. Yet, most everyone here says just crank the bolts and don't buy a kit. So, to do that, do you just lift the front end off the ground and start crankin'? Is there a certain number of turns or any formula to determine how much you are lifting for each turn and/or to determine how you have both sides equal? And, would swapping out the shocks for longer ones just help with the ride or would it also help prevent any extra stress or potential damage to the front end?
Old Feb 10, 2012 | 12:47 AM
Owensue's Avatar
Owensue
Yes there is a formula, 1/4 inch at the key = 3/4 inch lift.
In my comment I did say to skip the key removal and follow the tightening process.
Measure, lift, adjust, lower, drive, measure. Adjust again if needed.
Then alignment and headlights.
Yes, longer shocks can be added for ride comfort.
Old Feb 10, 2012 | 01:37 AM
freestyledude's Avatar
freestyledude
I'd recommend buying shocks that are 2" longer from what I've read.
Old Feb 11, 2012 | 01:29 PM
PRADO's Avatar
PRADO
Ya I leveled mine out and I have the stock shocks and they suck! Im am gonna get the shocks that are 2 inches longer.
Old Feb 11, 2012 | 01:42 PM
HammerZ71's Avatar
HammerZ71
You can get away with shock relocation brackets which reposition the factory shock, but factory shocks suck a$$, so I'd go ahead and replace...
