Need Help - what could different size tires do to my truck?
Old Feb 10, 2012 | 01:05 PM
houseoftoes's Avatar
houseoftoes
"The size differential won't have an affect on wear"---I find it hard to believe with all these numbers that are being thrown around in here that he would have even wear with tires that are not the same size.
So if someone drove 4K miles ( same size tires) with half of a vehicle on level street and the other half of the truck on level street but at a 1" elevation above the other half the tires would wear even? that would have no effect at all on wear?
Old Feb 10, 2012 | 02:28 PM
MoparPaul's Avatar
MoparPaul
Originally Posted by MikeHTally
The tires are NOT the same height. 275 is not the height, it's the width of the cross section. A 1" diameter difference isn't a great deal, but it does mean one wheel is rotating a fair bit faster than the other.
Your right,I really fudged that up
Dooley noted and corrected.
Sometimes I can't stink thraight.
Old Feb 10, 2012 | 03:42 PM
MikeHTally's Avatar
MikeHTally
All the tires will cover the same distance. The smaller tire will make 3.4% more turns than the larger one. I suspect there are factors (inflation, alignment, which corner the tire is on) that will have a larger effect on wear than the number of turns/mile. The tire manufacturers don't put a different wear warranty on tires that are the same brand/model but a slightly different size.
Old Feb 11, 2012 | 04:48 PM
rbatshon's Avatar
rbatshon
Tire rack Tire Tech Information
http://www.tirerack.com/tires/tirete....jsp?techid=18
Quote
Mismatched tires or using improper inflation pressures for all-wheel drive and four-wheel drive vehicles can also result in immediate drivability problems. Some Control Trac equipped vehicles in 4Auto mode may exhibit a shutter on acceleration and/or a noise from the front driveline and transfer case while driving. Some all-wheel drive and four-wheel drive vehicles may exhibit axle windup or binding while driving. Some four-wheel drive vehicles (manual or electronic shift) with a two-wheel drive mode may refuse to shift "on the fly" into 4x4 Auto or 4x4 High at highway speeds
As an example of different tire diameters resulting from tires worn to different tread depths, we'll compare two 225/45R17-sized tires, a new tire with its original tread depth of 10/32-inch and a second tire worn to 8/32-inch of remaining tread depth. The new 225/45R17-sized tire has a calculated diameter of 24.97", a circumference of 78.44" and will roll 835 times each mile. The same tire worn to 8/32-inch of remaining tread depth is calculated to be 1/8" shorter with a diameter of 24.84", have a circumference of 78.04" and will roll 839 times per mile. While the difference of 1/8" in overall diameter doesn't seem excessive, the resulting 4 revolutions per mile difference can place a continuous strain on the tires and vehicle's driveline. Obviously, the greater the difference in the tires' circumferences, the greater the resulting strain
