EVAP Leak
Old Feb 8, 2012 | 07:31 PM
Great White Wing's Avatar
Great White Wing
Default EVAP Leak
What is most likely cause of a persistent slow evap leak problem.
So far I have replaced gas cap with Dodge OEM after trying a cheapo.
Leak pump, EGR valve, canister, solenoid or hoses?
Do I need preformed hoses or does "off the reel" work? What size?
04 Ram 1500 Hemi with cab and 8 ft bed- the long one...
Old Feb 8, 2012 | 08:19 PM
kenneymc's Avatar
kenneymc
I had one and it was just a broken hose clamp. One of those cheap plastic ones they use. Put on a new metal one, problem solved. Check all the hoses on it too.
Old Feb 8, 2012 | 08:27 PM
Owensue's Avatar
Owensue
Mine had a split right near the fitting of the canister, I just cut out 3/4" and was good to go.
Old Feb 8, 2012 | 10:11 PM
PreacherOK's Avatar
PreacherOK
Mine had a vacumn hose split right on top of the canister as well. Really tough to see but there is a pretty good bend on that hose. Would not have seen mine but I happened to move it and it revealed the crack.
