engine code C6785
Old Feb 14, 2012 | 06:09 PM
NoLimitzR1's Avatar
NoLimitzR1
No a cycle is turning key on,that's a cycle when you cycle to off that's another so you actually did 100 not 95. For what its worth, get those codes every so often, I think it sets when you turn the truck on with door open, just a hunch, I wouldn't worry about it It's a silly setup if you ask me
Old Feb 17, 2012 | 05:11 PM
repsol's Avatar
repsol
ok its been 2 days check engine light comes back on and now the code is C0000. what is this?
Old Feb 17, 2012 | 05:44 PM
NoLimitzR1's Avatar
NoLimitzR1
0000 means no codes present or active
Old Feb 17, 2012 | 05:45 PM
NoLimitzR1's Avatar
NoLimitzR1
Check engine light to pull that set of codes turn key on n off three times you should get a code with a p in it. Post it when you get it, when codes are done the screen will say done. Do not push the trip button for these code pulls.
Old Feb 18, 2012 | 12:45 PM
repsol's Avatar
repsol
the light went out after i filled gas, have to wait for it to comes back on to do the 3xtime key to get code.
Tks
Old Sep 10, 2012 | 01:51 AM
garcia1711's Avatar
garcia1711
New Member
did you ever get it fixed im getting the same code "All door unlock output circuit shorted to ground or voltage
