Brake issues. And thanks.
Old Mar 9, 2012 | 10:14 AM
HEMI1980's Avatar
HEMI1980
Talking Brake issues. And thanks.
First off I wanna say thank you to JusJay, DirtyDog, Hammer, and any of the other guys I might have forgotten that helped me out over the last two months with questions. Just so you know that in the end I did just complete all my upgrades. Below is what I put on.
1. BELLTECH STREET PERFORMANCE SHOCK
2. MCGAUGHYS 2/4.5 DROP
3. EBC GREEN STUFF BRAKE PADS
Now some technical questions.
A. When I brake there is a whistle/squealing sound, what makes that and how does it go away ?
B. I am thinking of putting a tuner on the truck, what are a few you recommend ?
Old Mar 9, 2012 | 10:19 AM
Blacksport's Avatar
Blacksport
Old Mar 9, 2012 | 06:38 PM
bigdaddyII's Avatar
bigdaddyII
I have had a random squeak since i put the slotted rotors and ceramic pads on my truck. Its only an intermittant noise amd only happens once in a while, but wasnt there before. I think it has to do with the ceramic pads. Its only the drivers rear that does it.
Old Mar 9, 2012 | 07:09 PM
freestyledude's Avatar
freestyledude
try putting disk brake quiet on the back of the brake pads. I've heard of some people using grease on the anti-rattle clips as well.
Old Mar 9, 2012 | 09:39 PM
HEMI1980's Avatar
HEMI1980
I listened very close today. And yeah it pretty freaking annoying. The break pads which are the GREENSTUFF squeal terrible. It almost sounds like someone who needs a new break job. The really squeal. i have never encountered that before with dodge breaks, or pepboys or whoever. I upgrade to supposedly really good pads and they sound horrible. When does this break in period stop ? Also whats the input on performace tuners, I was thinking the VIVID LINQ.
Old Mar 10, 2012 | 05:31 PM
MoparPaul's Avatar
MoparPaul
A simple fix. Remove the calipers and pads. Look carefully at the pads & insides of calipers. Take note of any shiny spots where the pad is contacting the caliper. Take anti-sieze and apply a thin layer on all of the areas where contact is occuring. The squeal is caused by high frequency vibration caused by rubbing at these areas. A light coat is all that's needed. Don't forget the point where the piston hits the back side of the pad also you know the metal clip? Well I removed it and I put grease on BOTH sides of it. This has successfully stopped any squealing on my truck.
Another old trick is to bevel the edges of the pad. Grind a 45 degree bevel halfway through the thickness of the pad at the leading & trailing edges.
Old Mar 12, 2012 | 12:11 AM
HEMI1980's Avatar
HEMI1980
Pictures are soon to come. But I am still looking for information regarding performance tuners and what you guys think of the VIVID LINQ ? And through some research I have found that many people say the 6000 pads squeal through about 500 miles worth of break in. Which I do find bizarre because with OEM pads there is no break in. I have never had squealing with mopar, or raybestos. Yet with EBC which is supposed to be a upgrde to your OEM pads they squeal, so annoying. And besides the pad issues, and performance tuner opinions, what are opinions on putting in the little magnaflow Y pipe ? I dont understand the benefit of that little $25 piece.
Thanks,
M.W.
