alignment ???
just put some new 35's on and was wondering if i should get the truck aligned ?? i know rule of thumb was if you lower or raise the truck or car it should get aligned , the only reason i ask is because the stearing wheel is just a little off center going straight,
also the steering wheel is a little loose i have heard of this because of the size of the tires i believe , is a stearing stabalizer neccesary and do they make one for a 04 1500???
