CAI Problem
Old Mar 12, 2012 | 05:36 PM
gHEMImorePower's Avatar
gHEMImorePower
Default CAI Problem
I just finished installing my homeade cold air intake with a K&N high flow air filter and everything works well except for one thing. My check engine light is on :/. I guess it has something to do with the IAT sensor. Please give me some feedback, thanks.
Old Mar 12, 2012 | 05:44 PM
slakker25rs's Avatar
slakker25rs
I installed my CAI without issue. The tube has a small hole in it with a rubber seal. The IAT sensor doesnt even fit all the way into the hole, but I ve never had a CEL. Drill a hole in the tube and use a rubber gasket from autozone to hold it.
Old Mar 12, 2012 | 06:52 PM
Blacksport's Avatar
Blacksport
Did you un-hook the battery? It will reset the PCM, and your CEL should go away.
Old Mar 12, 2012 | 07:58 PM
gHEMImorePower
I did not un-hook the battery
Old Mar 12, 2012 | 09:02 PM
scwpd's Avatar
scwpd
Unhook your battery for 20 min or just unhook and touch negative and positive wires together for 20 sec and it should clear
Old Mar 12, 2012 | 10:03 PM
SLT8's Avatar
SLT8
If it comes back then you can go to your local Autozone or another auto store to have them read the code for you and then Google or post here.
You can pull the code yourself if you have a programmer but i am assuming you don't.
Old Mar 13, 2012 | 01:15 AM
08HEMI1500's Avatar
08HEMI1500
Or do the key trick to pull codes
Old Mar 13, 2012 | 03:11 AM
gHEMImorePower
No worries, the check engine light went away, the iat just had to adapt to this new environment I guess lol
