O2 Sensors
Old Mar 12, 2012 | 05:49 PM
slakker25rs's Avatar
slakker25rs
Default O2 Sensors
Hello all, I had an issue with hard stgarting while warm and replaced a Fuel Injector. Ever since, it seems my MPG has dropped. I verified it was the correct injector just to be sure.
I was wondering what the life is on the O2 sensors. I have never changed them nor had issue with them. I like to change them as more of a maintenance item and replace them at 100,000 miles at the latest, but Since there are 4 I havent done so yet. The truck has 146000 on it.
What are some opinions on the life and change interval? Has anyone had any fail?
Old Mar 14, 2012 | 12:25 PM
slakker25rs
So nobody has anything. We have bullet proof o2 sensors then. Cool
Old Mar 14, 2012 | 12:42 PM
HammerZ71's Avatar
HammerZ71
Estimated serviceable life of an O2 is 100,000 miles after which time they will degrade and can often cause driveability issues even though not being bad enough to generate a CEL.
I have 104k on my Grand Cherokee and probably need to do mine. I was about to do them an a bunch of maintenance stuff at the turn of the new year, but the place I was working decided to go into receivership about two weeks before my radiator decided to split at the seam. So obviously, for the time being my maintenance is going to be cut to just the absolutely necessary ones and mods are going to be pretty much non-existent until things turn around a bit...
Old Mar 14, 2012 | 01:47 PM
slakker25rs
Yeah that is how Ive always felt on the matter of 02 sensors. Sorry to hear about work. Isnt life fun. Its a pleasure to be on the forums with you. Thank you for all the help
Old Mar 14, 2012 | 02:27 PM
NV290's Avatar
NV290
How big of a job is it to do yourself? I understand you just use a special socket to remove and install them and the ones post Cat are easy to get to. But what about the two primary ones? Anything need to be removed to access them? Any special concerns? And is thier a certain brand worth buying and/or avoiding? I just hit 102,000 so maybe I should plan on doing mine. My mileage is ok, but if its due soon, may as well.
Old Mar 14, 2012 | 03:51 PM
rideon20z's Avatar
rideon20z
i have one that says low voltage but i dont even know how to tell which ones are which , i only have 75k on my truck,
Old Mar 14, 2012 | 04:19 PM
slakker25rs
I took a long peek under the truck and all 4 seem pretty accesible to me. It doesnt seem to be any issues as far as I can tell. They are 4 wire and there are 2 precat and 2 post cat with different part numbers. Precat Bosch 13869 25.99 Each - PostCat Bosch 15510 23.99 each.
I never used the special wrench. I use a regular wrench and take extra precaution due to the conditions of the exhaust.
I just ordered them from amazon, but they have them at auto zone too.
Old Mar 16, 2012 | 07:05 PM
NV290's Avatar
NV290
Just picked up all 4 at Auto Zone. Same Bosch part numbers you mention.
I would like to try and throw them in tommorow afternoon. Ill try and get some pics and some blow by blow details if anything needs to be adressed. I figure it's always good to have detailed step by step instructions on the forum for others.
Old Mar 16, 2012 | 08:21 PM
slakker25rs
dont you dare steal my spot on the FAQ. Haha. Im gonna do mine tomorrow also. Good luck to you and yours
Old Mar 16, 2012 | 10:47 PM
NV290's Avatar
NV290
You as well.
I am planning on doing this with the truck on the ground. Crossing my fingers i will need to jack it up. But the ground clearence should be fine to do this.
