hello everybody
Old Mar 21, 2012 | 11:40 PM
pepe_luis's Avatar
pepe_luis
Default hello everybody
hello there, This is my firs post I need some help I own a ram 02 4.7 4dr 133,000 kilometers Im having some bucking sensation while driving replaced spark plugs with champion NO cel light went to autozone and nothing came out I turned the key on and off 3 times and odometer showed P1391, could somebody tell me which sensor is bad? cam or crank sensor? Why the check light is not on and code scanner is not showing nothing?
thanks..
Old Mar 22, 2012 | 09:50 PM
Caseys-dodge's Avatar
Caseys-dodge
Welcome to the site!
Well I checked that code and it tells me the same thing, either the cam or the crank sensor. It's kind of funny that they can have so many different codes yet they don't have a code to say which particular sensor it is. I had the same code a while back and switched both sensors - when they went bad it made my truck impossible to start sometimes, it would crank and crank just fine, just never fire.
I think that the computer has to detect the fault 20 or so times in a row before it will light up the check engine light. I think it's something like a pending or stored code before it becomes an active code.
Old Mar 22, 2012 | 10:47 PM
slakker25rs's Avatar
slakker25rs
Good luck my friend and welcome to the forum. We welcome you
Old Mar 22, 2012 | 10:49 PM
pepe_luis's Avatar
pepe_luis
well, I did replace the crank sensor today and still doing the same thing but feels a little less bucking, I noticed that the magnet on the crank sensor was weaker than the new one, Im just going to wait for the cam sensor to arrive and see if that one fix the problem
Old Mar 23, 2012 | 07:38 PM
Caseys-dodge
have you also kept up with the other routine maintenance, have you ever cleaned out the throttle body? That's been known to cause rough idle problems.
Old Apr 5, 2012 | 12:15 AM
pepe_luis's Avatar
pepe_luis
I found the problem, here a some pics
Old Apr 5, 2012 | 12:18 AM
pepe_luis's Avatar
pepe_luis
