steering fluid leak
While changing my oil today I noticed a small amount of fluid on the bottom of my steering rack. It looks to be coming from the hex head plug (1 1/4" ?) that points downward. My fluid is withthin range and I don't think I feel any steering issues.I have a little over 71,000 miles on her. Should I be concerned,or expect problems soon?
Thanks!!
Thanks!!
Take a good engine cleaner and clean everything GOOD and then see where exactly it is leaking from. Mine also had a small leak on the PS line just as it came into the rack. As said before, a good worm gear fixed it.
Thanks for the responses,I will get it cleaned up and see exactly where it is coming from. I really know zero about steering(power or not) and cannot identify the parts by name.My service manual(Haynes) seems very vague on description too.Is there somewhere else I can find info on parts and descriptions?
I miss my old Clymer motorcycle manuals where EVERYTHING has an exploded view and even the nuts and bolts are labeled.
Well the worm clamps didn't fix mine I even replaced on line to the cooler and still have a leak guess I am going to have to change the other line. I know the pressure side of the system is 1650 psi but the return seems to be where it is leaking.
