Last edit by: IB Advertising
Browse all: Engine Guides
- Dodge Ram 2002-2008: 4.7L vs. 5.7L Hemi Engine Difference
Important information to help you understand your Ram
4.7 vs 5.7
Thanks for all the feed back already own the hemi just curious if it was as susceptible to over heats .
I bought a 180 tstat but sent it back after reading that this could shorten not lengthen life of hemi just like my optimax needs to run at a certain temp to keep heat transference at optimal .
I tow 18 bass boat not sure how heavy but when it's hot that's when I'm towing the most any recommendation how to avoid any overheats
I towed a 20' Javelin bass boat for years. Bass boats are light and don't catch any air, I know you're under 3000 lbs. Even gassed up and loaded with gear. You should have no problem pulling it in heat. If you have the tow kit then you have a granny cooler. You'll be fine with normal maintenance.
Yeah I'm under 3500 for sure only 1 3500 lbs axle on trailer but I keep a lot of crap on board.
My other truck is 94 Chevy z71 180 stat and a huge radiator I could pull boat in the desert 150 deg not go over 1/4 way but it's got 220,000. And the new to me dodge rides awesome plus qc has more room
I pulled my Javelin on a couple of vacations, 6+ hours each way with my ex's '02 Grand Cherokee, 4.7 unibody framed 4x4 and it never even hinted at overheating. My Ram with a 180* thermostat and efan never got anywhere close to the half mark on temp and I pulled it all over south Georgia in 90*+ heat all the time.
Hell, I fished a tourney on Lake Sinclair in like '05 when it was over 100* every day. **** poor tournament, my surface temp gauge showed the water temp was 92*, you didn't get the early morning bite, you got bupkis...
