2003 2500 Hemi Fan Clutch Removal
Is it counter clockwise facing the engine. Were having a hard time holding the water pump from spinning. Help appreciated.
Yeah. Turn it to your left and stick a screw driver through one of the 4 holes in the wp pulley and it'll catch on something. I think I spun the fan to the right until a blade held the screw driver in place. And then tapped on the 36mm with a hammer to break it loose.
I put every size allen wrench I had. I bent them all. I heated it for 30 minutes and still no luck. I didnt have room for any of my screw drivers
I took a flat piece of steel and drilled 2 holes the same distance apart as 2 holes on the water pump pulley, was a pain but it worked. I'm sure there's a tool made for it. After the water pump was secure I took a hammer to the wrench and it came loose. Had to do this all because the rubber gasket that seals the water pump to the engine started leaking, what a pain.
Now time to tackle the leaking exhaust manifolds. |
I should add, I put 2 bolts in the 2 holes I drilled in the steel piece. The bolts went in the holes in the water pump pulley.
Originally Posted by tmodlin
(Post 2754483)
I used a air chisel to take the fan off my 2001 360. just hold the chisel on the edge of the nut and pull the triger and then I could spin it off with my fingers.
i just used a punch on the edge of one of the side and hit it with a hammer a few time to loosen it up
http://www.google.com/url?source=img...xxloJhNN-GksVA
get one of these and an air hammer...love this tool |
