Leveling question, please help.
Old Apr 1, 2012 | 02:45 PM
Aerogauge's Avatar
Aerogauge
Default Leveling question, please help.
So I just measured on my truck and the front is 3" lower than the back. So what is the best to simply raise the front 3" to match the rear? Spindles or coil spacers or what? Also which is easier to install? And both require alignment?
Old Apr 1, 2012 | 04:19 PM
Aerogauge's Avatar
Aerogauge
I am thinking about going with coil spacers, been looking on eBay but not sure which ones are good and which are junk
Old Apr 1, 2012 | 04:32 PM
08Hemi4K's Avatar
08Hemi4K
Not sure if you have a 2wd or 4wd, but you might wanna do a search, cause I don't think you wanna go any higher than a 2" lift in the front. It puts the front axles at a bad angle...especially when using spacers.
Might want to look into a set of Bilstein 5100's.
Old Apr 1, 2012 | 04:39 PM
Aerogauge's Avatar
Aerogauge
2wd, that sucks I really need 3" to get level
Old Apr 1, 2012 | 04:44 PM
08Hemi4K's Avatar
08Hemi4K
2wd might be a different story. Could be possible with spacers without any problems.
Old Apr 1, 2012 | 04:51 PM
Aerogauge's Avatar
Aerogauge
Hope so, anyone else know anything about 3" spacers on 2wd?
