Wheel-Well Rust
Old Sep 28, 2012 | 11:21 PM
jj141979's Avatar
jj141979
I use used motor oil. I save the oil from all my oil changes and use a undercoating gun with a air compressor. I also take the tail lights out and spray up inside the bed from the tail light hole. Works like a champ!
Old Sep 29, 2012 | 01:10 AM
cyclone429's Avatar
cyclone429
My right front fender rusted out were I drilled the hole for the mud flap, rust was starting on the out side fender near the drivers door, I was able to save the fender, and patch the hole with metal (roof flashing) now I need to work on my inner door seams as thier rusting again.
CLR helps take away some surface rust
Old Dec 30, 2012 | 04:26 PM
AZSpaniol's Avatar
AZSpaniol
I bought an 03 ram and there is no rust. I'm trying to prevent it as much as possible. I bought some texaco compound L. The design flaw that causes the rust are the holes under the wheel well that trap salt, etc right? So I would need to get the compound L inside the bed of the truck? What would be the best way of doing this? Thru the taillight area?
