Why does my front end wobble in 4wd?
Pretty funny because THESE guys feel the same way.
Please respond to them.
I'd say it's your leveling kit. Did you put the spacers on right when you got your leveling kit done or did your run the level in 4wd on stiock tires afor a bit with no wobble?
Many guys have experienced the same problem with level kits on stock tires. Not too sure the spacers or negative offset is the issue.
The original Post from Vikingdiesel mention a level kit, then he started experiencing a wobble.Which they say the level kit will enhance a shutter.
I hate to see some one spend all that time and money when a level kit might be the problem..Do a search in the forums and you will see lots on this topic.I hope the parts you replace where failed and not miss diagnosed..
