2002 tranny problem
Old Apr 21, 2012 | 10:23 AM
gbarton21's Avatar
gbarton21
Default 2002 tranny problem
I have a 2002 1500 4x4, 5.9. Last week it started slipping when you would put it into reverse. If you reved the engine a little it would start to move. A friend said the bands needed to be adjusted. So I let him and now it wont go itno reverse at all. I'm not much of a mechanic, but pretty handy, is there anyway for me to readjust the bands or is it major shop time. Thanks for any help you can give guys.
Old Apr 21, 2012 | 12:40 PM
Owensue's Avatar
Owensue
I know there are alot of sites with info on proper band adjustment.
When I had the same problem on my 02 I found a ton of them, then I found I had the 45rfe without the bands.
Follow the proper proceedure and you may be good.
Good luck
Old Apr 22, 2012 | 12:03 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
The Service Manuals available in the links in my signature can help you on how to adjust and if it is in your level of doing it.
Another thing to try is visit the 2nd Gen section and post a question as more if them have that trans and might be able to help mo
