04 1500 rear axle bearing, HELP!!!
Old Apr 24, 2012 | 01:39 AM
Redneck2345's Avatar
Redneck2345
Default 04 1500 rear axle bearing, HELP!!!
I have a 04 1500 with the 9.25 rear end, about a month ago it started clicking in the rear end, I took it apart and found that the drivers side axle bearing had went bad. I replaced it, now on my way home tonight, it started the same noise again! The install seemed pretty straight forward, is it possible I put the bearing in to far? I put it against the race like all other bearings usually are
Old Apr 24, 2012 | 06:27 AM
TrueDogman's Avatar
TrueDogman
The bearing rides on the axle surface. If the bearing was gone, the axle surface should have been marked and pitted as well. If you installed a new bearing with a worn axle, then new bearing will now be damaged. Unless you installed a new bearing repair it, which is a bearing that rides on a "new" axle surface.
Old Apr 24, 2012 | 10:40 AM
Redneck2345
That's the thing, the old bearing had spun in place and wore through the outter collar, I scuffed the old surface, and inspected the shaft and it didn't look very worn (enough to make a difference anyway) I'm totally baffled by it
Old Apr 24, 2012 | 09:40 PM
JSE414's Avatar
JSE414
How many miles are on the truck and what type of "abuse" have you put it through? (Towing, off roading, etc...)
Old Apr 25, 2012 | 02:18 AM
Redneck2345
It's got 105,000 on it, as for abuse I can't really say, I picked it up 11,000 miles ago. I haven't done much with it other than drive it normally. It is pushing 35's though. I haven't had a chance to take it apart yet though
