Randon Misfire
Old Aug 2, 2012 | 08:57 AM
Jkroye's Avatar
Jkroye
Hi db, any update on this? My truck is doing the same exact thing. It's the same year with the same mileage.
Old Aug 13, 2012 | 02:41 PM
dbmowersports's Avatar
dbmowersports
For those still interested, it was the upstream o2 sensors that were causing the misfires. I changed them last week, but I wanted to be sure they were indeed the problem.
Next paycheck I will change the downstream sensors as well.
I hope this helps others in the future.
HA!!!! I just noticed I spelled random wrong in the thread title!
Last edited by dbmowersports; Aug 13, 2012 at 02:44 PM. Reason: Because I can't spell.
Old Aug 13, 2012 | 03:23 PM
willdikem66's Avatar
willdikem66
Hmmm i have the same problem. wonder if its the same soulution
Old Aug 13, 2012 | 03:30 PM
Jkroye's Avatar
Jkroye
I have the same problem. I've done the plugs and wires. I also tried cleaning the throttle body (which was really dirty) based on other posts here. I still have the same problem though. This weekend it just threw a code for an upstream O2 sensor. I'll be replacing it this weekend.
Old Aug 13, 2012 | 03:43 PM
willdikem66
I just changed the plugs 100 miles or so ago and after clearing the misfire code it hasnt came back but when i first crank my truck it stumbles and shoots the RPM's up a couple hundred revs.
Old Aug 14, 2012 | 11:42 AM
dbmowersports
It'll cost you $80.00 and a little bit of time with a 7/8" wrench to find out. :-)
For what it's worth, mine also stumbled and raced at start-up. It doesn't do that anymore.
As I stated above, I waited a week before posting to be sure the problem was fixed. So far so good.
I have no idea which one was causing the issue because I changed them both, but if I had to guess it would be the driver's side (Bank 1).
Old Aug 14, 2012 | 11:52 AM
willdikem66
I wish i could just get a O2 code lol!! Luckily I have a O2 Wrench so it will be even easier but its just a matter of spending the money to find out if its the problem. A couple of things to add to the problem is my MPGs have been terrible lately (Usually Get atleast 15 on the highway and now i cant seem to get over 12) and its smells like shes running as rich as she can get to! Can you relate to any of that?
Old Aug 14, 2012 | 12:00 PM
dbmowersports
My MPGs did go down, but not that much. I was getting about 15.5 mpg when I got it the truck. (according to that overhead display) It was down to 13.5 mpg.
It's now back up to almost 16 mpg. I have no idea how accurate that is, though.
I remember when it idled, yeah, it seemed rich. I honestly haven't looked at the exhaust since I changed them. I'll take a look this afternoon and let you know.
Old Aug 14, 2012 | 12:11 PM
willdikem66
They say the overhead is fairly close. I figure its math is better than mine. But i also dont drive more than 3 miles of highway so its probally not getting a chance to reach the good MPGs But its still way off from when i first got the truck and i know its rich and runs goofy at the start up, so i guess ill look into some o2s.
jj141979's Avatar
jj141979
To everyone that is changing there o2 sensor! Only use mopar o2 sensors! I had the same problem 3 years ago with mine. Don't use anything else! I blew through $300 in bausch and some napa brand and neither one would work. I finally went to the dealer and got a mopar one and its been fine ever since.
