Idle issues
Old May 3, 2012 | 09:20 PM
GeorgiaE30's Avatar
GeorgiaE30
Default Idle issues
Im sure this has been brought up before but,
02 ram 5.9 magnum. When in park the idle with go between the normal 600ish rpms to almost 2k. However when i rev it once that goes away or it eventually settles down. I know our trucks are not electronic throttle controlled so am i looking at a sensor?
Old May 4, 2012 | 12:19 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I think Hammer would say plentium (sp) leaks?
Old May 4, 2012 | 08:25 AM
HammerZ71's Avatar
HammerZ71
Look down the throttle body with a flash light. If you see oily residue then Yuri Plenum gasket is blown. Very common on the Magnum 3.9, 5.2 & 5.9 engines...
Old May 4, 2012 | 12:15 PM
GeorgiaE30's Avatar
GeorgiaE30
Is that the gasket that is between the block and the intake manifold?
