2003 Hemi Cam
Old May 14, 2012 | 12:36 PM
sxe_death_eather's Avatar
sxe_death_eather
Default 2003 Hemi Cam
can a cam for a 2004 hemi fit into the 2003 im in the market for a cam upgrade but its hard finding them for a 2003... any help will do thanx in advance
Old May 14, 2012 | 02:46 PM
SLT8's Avatar
SLT8
Mechanically yes but gotta research on a grind that will work with a 03 computer.
Old May 14, 2012 | 06:00 PM
HammerZ71's Avatar
HammerZ71
Yep, technically any pre-MDS cam will fit, but getting a tune to tame one on an '03 PCM narrows your choices down a good bit...
Old May 14, 2012 | 08:14 PM
HemiLonestar's Avatar
HemiLonestar
Do you mean an aftermarket cam or a stock 04 hemi cam? If it's a stock hemi cam it will be the same as your stock 03. Most you'll probably want to go with an 03 computer is a comp 260 type. I noticed your little info thing in the corner says you have a 2000 with a 318? Are you swapping this in or for a different truck entirely?
Old May 14, 2012 | 11:10 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah, best cam for an 03 is a Comp Cams 260, 6.1 or FRI Sidewinder
