2008 2500 Steering Upgrade
Old May 14, 2012 | 10:35 PM
travisfimple's Avatar
travisfimple
Cool 2008 2500 Steering Upgrade
I have an '08 2500 4x4. Handling was always a little sketchy and I put a 2" leveling kit with 315s on it. Now I get the death wobble when going over 60 after hitting a hard bump.
Anyone out there used the Mopar steering upgrade 52122362AH, or AF AE etc? Did this fix the problem? I know this T linkage is much better than the factory installed Y steering. Also not sure if I need a new pitman arm, says I do if made after March '08 but I have no clue when mine was. Sounds like I need a new stabilizer also to work with this upgrade? Looking for some input on your experience with this kit or something similar.
Here's the cheapest I could find everything including a new stabilizer. Let me know if you found a better kit or cheaper price... http://www.highhorseperformance.com/..._p/pk362af.htm
Old May 14, 2012 | 10:47 PM
cyclone429's Avatar
cyclone429
Ask dodge to buy it for you. I'm realy bitter as I had the drag link fall the right hub while backing up, as far as I know the new mopar drag link is still a compression fit on the right hub, no lock nuts or cotter pins under the hub to safe the drag link from falling off.
Old May 14, 2012 | 10:51 PM
cyclone429's Avatar
cyclone429
sorry compression fit under the hub, thiers still a ball socket and bolt on the top
Old May 17, 2012 | 09:58 PM
travisfimple
Wink
Something tells me that my leveling kit and H2 wheels have voided any warranty on my steering and suspension
Old May 19, 2012 | 12:05 AM
cyclone429's Avatar
cyclone429
All componants on the 2500 ram stearing and suspension don't hold up on a stock truck, non servicable is the dodge way, lift kis, over size tires using stock ball joints, front u joints on the drive axle is one quick way to cook a dodge 2500 front stearing componants and ball join
ts,
