06-08 Uconnect radio/mirror
Old May 20, 2012 | 02:54 AM
scrboy09's Avatar
scrboy09
Default 06-08 Uconnect radio/mirror
so i have a 2006 ram 2500 and i want to put a 2008 ram oem radio in my truck with the Uconnect feature will this have the same connectors as my 06? and do i need the uconnect mirror for it to work even though there is a button on the radio?
Old May 23, 2012 | 08:07 AM
Brandon Anderson's Avatar
Brandon Anderson
For factory uConnect to work with the REC radio, you'll need the following:
  • Mirror: 05064017AD
  • Mirror harness: 56051317AC
  • BT module: 05064013AV
  • BT harness: unavailable if not wired for uConnect from the factory
There used to be a guy on one of the LX forums that made the required harnesses to make everything work, but I'm not sure if they are still available. The alternative is the plug-in dealer installed uConnect that mounts on the dash. It's cheaper, but doesn't allow for the uConnect mirror.
