How to remove AAM 925 axle seal
Old May 25, 2012 | 09:35 PM
texram2007's Avatar
texram2007
Default How do I remove AAM 925 axle seal?
I am replacing the axle seal on my 07 Ram 3500 and ran into difficulty removing the old axle seals. I was considering using a dremel with cutting wheel to get them out, but figured I'd ask if anyone had advice first. If anyone has been through this already I'd appreciate if you would share your solution to the problem.
Old May 26, 2012 | 08:24 AM
dirtydog's Avatar
dirtydog
Moderate User
Most use a seal puller or a dent style puller with a slide weight.
Places like Advance Auto and AutoZone rent those for free with a small deposit refundable on return.
I would NOT suggest using a dremel. You'll throw metal shavings all into the bearings right behind the seals. Not good!
If anything, use a prybar/screwdriver and get behind the seal and work your way around. Don't pound on the seal inwards in any way with the screwdriver. You can risk pinching the bearing.
seal puller
slide hammmer style
A very large socket is used to tap the new ones into place.
