Old Aug 5, 2015, 07:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior
Print Wikipost
Just replaced the infamous Recirculation Door in 30 minutes :-)
Old Jun 6, 2014 | 07:32 PM
  #31
rayoj's Avatar
rayoj
replaced this door in april 2012 and the same one is broken again. Even though the cost is a lot higher for the heater treater door I think its worth it instead of dealing with this crap again in 2 years. I live in AZ and I need my re-circ A/C. lol
Old Jun 7, 2014 | 03:19 PM
  #32
fj5gtx's Avatar
fj5gtx
to be clear, did you replace it in april 2012 with a factory door.. Dorman part, or what?
Old Jun 8, 2014 | 01:56 AM
  #33
nickm5's Avatar
nickm5
Just fixed mine today!!! It was so easy!! Thanks for the write up
Old Jun 8, 2014 | 09:47 PM
  #34
Will_V2Lab's Avatar
Will_V2Lab
Good info! Thanks for the write up! Mine doesn't have this problem but at pushing 10 years old it can't be too far away. Better to know now than to search and whatnot to find a solution lol
Old Jun 8, 2014 | 11:11 PM
  #35
rayoj's Avatar
rayoj
I replaced it with the factory door, and the cost at my local dealer was about $80.00. Did not know about the dorman part back then and did not hear about it until after I ordered my heater treater door. Tried to go cheap last time, and decided I would spend the extra 40 bucks compared to the factory one and fix it for life. Also if any other doors break heater treater only charges about $45 for the other doors after you purchase the 1st one.
Old Jun 9, 2014 | 12:08 PM
  #36
thunderhawk09's Avatar
thunderhawk09
If your like me and didn't want to spend the money right now to do the job buying the new door just remove blower motor reach up through blower motor hole and get the recirculate door turned just right and it will come right out it took like 7 minutes to do it now mine bolws normal I just get a mix of fresh air and recirculated air no big deal at least it blows normal now
Old Jun 14, 2014 | 08:42 AM
  #37
JOHNSN10's Avatar
JOHNSN10
Put that how to in the how to section. Great job with this one
Old Jul 26, 2014 | 04:12 PM
  #38
electraflh's Avatar
electraflh
great post, i had same problem, heres my hillbilly fix, take blower motor out and reach up and pull broken door out, remove glove box and you can see fresh air screen, you can put a piece of dynamat over screen or other sticky junk (no duct tape it falls off) or what i did, go to home depot buy a can of expanding foam poke a hole in the screen from the glove box, stick the can and nozzle up the blower motor hole and into hole in screen and squirt away, no more fresh air but it takes 15 mins and only costs 5 bucks and works great
Old Sep 14, 2014 | 04:06 PM
  #39
chrisbrn2000's Avatar
chrisbrn2000
Default Recirc Door
Just replaced my recirc door on my 03 Ram truck, it was a pretty easy job except for the back screw on the motor, good thing i had a flexible extension screw driver that made it much easier to take off the motor.
Old Sep 24, 2014 | 11:52 AM
  #40
tvacchino's Avatar
tvacchino
I've been "living" with this now for 2 plus years. I always seem to forget about it during nice weather. But come Hunting Season... COLD FEET!!
Also I have the Infinity sound system so it's gonna be a pain in the Butt regardless.
out,
t
