Intermittent lamp out warning light
Old Jun 14, 2012 | 08:50 AM
Bigboytoys's Avatar
Bigboytoys
03Whiteram-If it is coming on during braking and left turning it means it is one of the turn bulbs. I know you said you replaced them, but it could be that the contacts are worn in the socket itself. I had this happen on a old Mazda B2300. Granted it did not have the circut board but the principle remains the same (don't know if circut board replacement replaces the socket themselves though.)
Old Jun 16, 2012 | 02:38 AM
03whiteram's Avatar
03whiteram
That is something I have yet to get through. I will be looking closer into the connector that locks into the circuit board. That's the only thing I haven't done yet, aside from replacing the connector on the liscense plate light, which I know has a loose wire.
Old Jun 20, 2012 | 08:51 AM
ah21283's Avatar
ah21283
Originally Posted by 03whiteram
I had/am still having issues with this. I replaced the circuit boards/all bulbs, headlight bulbs and such. The damn chime/lamp out light only comes on during bumpy conditions, or sometimes just because. We can go days without it, and sometimes we can't go 1 minute without it constantly chiming. Aside from the random times it may come on, most of the time it's during braking and left turn signal activation. I am lost right now.
Having this EXACT same problem, probably the most annoying thing ever
Old Jun 20, 2012 | 05:51 PM
74hemi04ram's Avatar
74hemi04ram
i had this same problem with my 2004 ram. turned out it was the third brake light. may want to give that a look.
Old Jun 21, 2012 | 10:58 AM
03whiteram's Avatar
03whiteram
Will be looking at the third brake light when I get home...that's the only thing I haven't looked at.
Old Jun 24, 2012 | 11:02 PM
ccaamm1's Avatar
ccaamm1
Mine did the same thing this past week. Step on the brakes and ding, ding. Lamp out warning flickered at first then stayed on, then would go out. Turns out it was the metal contact on the passenger side brake light bulb itself. There was a little bit of corrosion on it causing the intermitent warning light and the annoying ding sound. Replaced all four signal/ tail/ brake lights as the others looked like they would be going soon too. Cheap easy fix. '04 1500 Hemi. Check the bulb contacts. The filaments may look o.k. making you scratch your head thinking you have bigger problems with the sockets and wiring, when its just something small and simple. Yet hard to spot at first.
Old Jun 26, 2012 | 01:23 AM
Bigboytoys's Avatar
Bigboytoys
03Whiteram-You get your issue fixed yet? Definately look at getting the socket connectors looked at/replaced...
Old Jun 26, 2012 | 03:19 AM
03whiteram's Avatar
03whiteram
I should be back in the states in about 15 days.
Just a recap of what I tried in May while on R&R.
1. Replaced all brake/turn signal bulbs (4 each)
2. Replaced both circuit boards with new ones.
I have not:
1. Replaced the third brake light bulbs (don't know if this affects the left turn signal lamp out)
2. Checked/cleaned the connector to the circuit boards.
3. Fixed the shorted wire to my liscense plate lights (one flickers; don't know if it plays a role in the lamp out during braking and left turn signal)
This weekend, my wife took it up for the safety inspection and passed, eventhough the lamp out chime was dinging the whole time.
Will be digging into it when I get home. Can't wait to get out of this damned place.
Old Jun 30, 2012 | 01:59 PM
04FloridaHemi's Avatar
04FloridaHemi
Glad to know I'm not the only one loosing my mind. Mine does it on long trips, with or without the trailer in tow, day or night. I've traveled 14 hours and nothing, then it will just ding for a couple hours. Almost feel like buying a couple circuit boards so I can do a roadside swap if necc, have a long trip in August. I think I'll start with cleaning all the contacts and regreasing them w/ dielectric grease.
Old Jul 23, 2014 | 01:09 PM
M.A.D's Avatar
M.A.D
Have an 03 Dodge Ram 1500, my lamp out keep flashing off and on. Than the chiming noise does the same when the lamp out. Start acting up and than sometimes the chime noise start before the lamp out goes in and out.
