Overheating problem...
Old Jun 14, 2012 | 10:38 AM
TBarCYa's Avatar
TBarCYa
I actually know the source of the blown head gasket... When I put the reman engine in, I put a brand new water pump in with it but that pump failed and caused an overheat. Not to the point that the engine shut down but I pulled it over when I noticed the temp was almost at the pin. The metal impeller actually broke off the shaft leaving a 1" disk on the shaft. I should have known something was wonky with the water pump when I had to shim the idler pulley to get it to line up with the belt.
Old Jun 14, 2012 | 11:25 AM
mustang_170556's Avatar
mustang_170556
i've had blown head gaskets without getting coolant in the oil, so one of these kits would definitely be a good idea. i also had never heard of them.
