Will any R17 tire fit my stock rims?
Old Jul 29, 2012 | 10:09 PM
team_realtree's Avatar
team_realtree
Default Will any R17 tire fit my stock rims?
I want the biggest tires I can get without changing my rims out. Is there a difference in the width on some rims? I've seen bigger tires marked as 12.50 or something as the width rather than in MM?
Old Jul 29, 2012 | 10:22 PM
08HEMI1500's Avatar
08HEMI1500
Well your title doesn't really match your question but yes 17 inch wheels are the smallest you can go on a 3rd gen Ram. As for the width I think in 17s the widest width I've seen was 9 inches which is what you want if you're going for 12.50 inch wide tire but I believe you can get away with a 8 inch wheel too
Old Jul 29, 2012 | 11:09 PM
HammerZ71's Avatar
HammerZ71
Generally you can go with a tire that is about 4" wider than your wheel width max. For factory 17x7 that would mean 11" wide tires, for factory 17x8 this would mean a 12" wide tire max.
For a 12.5" wide tire you should be looking at an aftermarket 17x9 or a 17x10 wheel. Then you need to start thinking about offset and backspacing to make sure it'll clear front end components...
Old Jul 29, 2012 | 11:24 PM
08HEMI1500's Avatar
08HEMI1500
They make a 17x10!? The widest I've seen is a 17x9. That's crazy wide for a small wheel but I can see it for like drag racers
Old Jul 29, 2012 | 11:30 PM
HammerZ71's Avatar
HammerZ71
Hell, I've had 15x10 wheels...
Old Jul 30, 2012 | 05:16 PM
gcburkett's Avatar
gcburkett
Go to tirerack and look at the specs it will give you the rim width range. So like a 265 on a 7" or 305 on a 8". Personally I would think keeping it near the measured rim width is ideal.
Old Jul 30, 2012 | 06:01 PM
p38251's Avatar
p38251
I run 285/70/17 on a 9 inch wide rim. I used tire rack to make sure I got the correct offset and back spacing as well. Post pics when you get um
