Tire inflating question
Old Aug 3, 2012 | 09:16 AM
p38251's Avatar
p38251
I run 10ply tires for towing. I run 40psi unloaded. I air up to 70psi in the rear and 60psi in the fronts. I air back down after I get where I'm going.
Old Aug 3, 2012 | 12:04 PM
shardy's Avatar
shardy
Originally Posted by Chet Ubetcha
The door sticker is from the factory for the stock tires it shipped with. I've always heard and read (I've seen a few charts out there that actually break it down by front and rear axle weight) right around 65% of max stated on the tire for daily driving, and 80% (or more as needed) if towing/hauling.
Originally Posted by hemi4109
The sticker is for P rated tires... that number is now useless with your LT tires. 50-60 seems to be a good range for most and I air up to about 65 since I use my truck a lot for more than getting groceries. I don't think you'd ever need to go up to 80 tho unless you've got a yard of gravel in the back.
Alright I will go with that. Thanks everyone else for their comments too, I learned stuff reading you.
Old Aug 3, 2012 | 01:33 PM
joebaum's Avatar
joebaum
How ! Many diff thoughts.
If you have anything other than p rated tires you need to air up more than door specs.
This is a truck , yes they ride
Rougher with c, d, e load rated tires , but they will b sponge at extreme low pressures . Get those side walls off the ground .
