rear end trouble
Old Aug 25, 2012 | 01:51 PM
union millwright's Avatar
union millwright
Default rear end trouble
okay started getting a loud popping noise, so i took the cover off the rear end and seen that i have metal chips laying in the bottom of the housing. i noticed they where the teeth off of the driver side axle. they are also 2 gears that go from one axle to the other can some one tell me what they are called or have the layout of the rear end? also can i change these with out messing with the ring and pinion? thanks for any help
Old Aug 25, 2012 | 03:28 PM
HammerZ71's Avatar
HammerZ71
Do a search in this section for "c-clip" you'll find all the information you'll ever need and then some...
Old Aug 26, 2012 | 12:35 AM
sabin420's Avatar
sabin420
long story short, the c-clip fell out of the driver's side axel. yes you can change the axels without messing with the ring and pinion.
Old Aug 26, 2012 | 06:25 AM
abarmby's Avatar
abarmby
Groan.....another poor guy needing help with this terrible problem. Dodge just won't "manu up" .
Good luck to the op and I hope your axle isn't all chewed up by those clips?? Otherwise thats an expensive repair right there.
Al.
