New Spindles are hitting sway bar ends
Old Sep 17, 2012 | 05:07 PM
team_realtree's Avatar
team_realtree
Default New Spindles are hitting sway bar ends
I put in lift spindles and they are shaped differently so now at full lock they push the vertical sway bar ends that come out of the lower control arm against the coil spring. Is this bad or will they just bend a bit lol
I can't think of a solution other than go swaybar-less
Old Sep 20, 2012 | 11:46 AM
bestram's Avatar
bestram
are you sure the spindles are the correct ones for your truck just asking because mine don't do that
Old Sep 20, 2012 | 11:50 AM
willdikem66's Avatar
willdikem66
I would assume not being in all the way/or in right. Or not the ones for your truck.
Even though the key fits dosent mean it turns the lock
