Swapping My 2003 Ram Hemi
Good job. And a tip on a spark plug removal tool, use the boot of an old spark plug wire. It's flexible and can get in the tight spots. Cut the wire off the end and leave the other end inside the boot. It will snap onto the spark plug and pull it out, you can also start the threads that way. You will never cross thread a spark plug that way.
Yeah, you put the boot on the plug then put it in the hole. Then spin the boot clockwise to start threading the plug in the hole. It gives you just enough force to turn the plug. Then, snug it up with your socket (remove the rubber from inside your socket if you have the problem of pulling the socket off the plug).
Thanks...yeah definitely satisfying. Even though I have decent mechanical ability, I must say I was pretty intimidated doing anything other than oil changes and brake pads on this truck. So undertaking the project was a bit scary. After doing this, I definitely have a much bigger comfort level working on this thing.
As far as mods...probably nothing more than an intake. Hopefully next year I'll have finances more in order and will be in the market for a used Charger...and that will likely be what I mod.
Looks good i hope she runs 150,000 good miles
