2006 ram tranny problems
Old Sep 21, 2012 | 09:52 PM
kyleenright's Avatar
kyleenright
Default 2006 ram tranny problems
Ocasionaly when I go to leave work at the end of the day(after 8 hours of sitting) my auto transmision will act as if it is slipping for a few seconds when I go to take off, but is fine after. What could be causing this?
Old Sep 22, 2012 | 06:43 AM
scwpd's Avatar
scwpd
Have you had the Trans serviced lately it sounds like the converter is draining
Old Sep 22, 2012 | 09:16 AM
1500hemi4x4's Avatar
1500hemi4x4
mopar updated the trans filters for these truck cause they were splitting in half i would get 2 new filters one spin on and one filter and do the service .would not hurt to see if the is any trans/tcm updates avalible from dodge either
Old Sep 22, 2012 | 02:57 PM
hemi4109's Avatar
hemi4109
As per the Owner's manual, they say it's normal for the torque converter to drain itself a little causing that temporary symptom.
Old Sep 24, 2012 | 01:40 PM
DodgeCares's Avatar
DodgeCares
Kyle,
While it could be a few different things causing this I did find one TSB that mentions the symptoms you describe. Copy below.
NUMBER: 21-007-06
GROUP: Transmission
DATE: April 07, 2006
SUBJECT:
RFE Transmission Filters - Delayed Engagement And Related Transmission DTC'S
OVERVIEW:
This bulletin involves verifying the build date of the transmission, and if necessary, the
replacement of both the cooler return and sump filters in the transmission.
MODELS:
2005 - 2006 (DR) Ram Truck
2005 - 2006 (HB) Durango
2005 - 2006 (KJ) Liberty / Cherokee
2005 - 2006 (ND) Dakota
2005 - 2006 (WK / WH) Grand Cherokee
2006 (XK) Commander
NOTE: This bulletin applies to vehicles equipped with the a 45RFE or a 545RFE
automatic transmission (sales code DG4 or DGQ respectively) having a
specific transmission build date code (see the below DIAGNOSIS section for
further details).
SYMPTOM/CONDITION:
The customer may experience an initial delayed shift engagement following an extended
off (not running) period of time, generally after being parked overnight. The initial shift
engagement may feel like a delay or slip when a transmission gear (reverse or drive) is
first selected after engine start.
The customer may also experience a MIL illumination. Investigation may determine that
the MIL is due to one or more of the following Diagnostic Trouble Codes (DTC's):
P0868 - Line Pressure Low. This DTC will be the most frequently occurring DTC for
the delayed shift condition.
P0944 - Loss Of Hydraulic Pump Prime.
P0731 - Gear Ratio Error In 1st.
P0736 - Gear Ratio Error In Reverse.
P0841 - LR Pressure Switch Rationality.
P0876 - UD Pressure Switch Rationality.
The delayed engagement and MIL condition (DTC's) may be caused by a suspect
transmission cooler return filter.
