Need a Little help diagnosing a noise...
Old Sep 22, 2012 | 12:05 PM
NJMandCEM's Avatar
NJMandCEM
Default Need a Little help diagnosing a noise...
Hello all.. I've been listening for over a week now what i thought was my drive belt squealing/squeeking... i figured i'd start cheap and get some belt conditioner and see what that does... did not change the noise at all... so when i had the belt off i figured i'd play with all the pulley's... they all spin with any noise... until i got to the water pump... and spinning the pump pulley by hand it sounds just like a belt would... Any suggestion to what i should do?? can the pulley itself be replaced with out doing the whole pump?? can it be lubed?
Thanks..
Old Sep 22, 2012 | 12:14 PM
willdikem66's Avatar
willdikem66
You have to pull the Water Pump period to change the Pulley and the Upgraded designs they have make a new water pump better. 14-17 bolts on the pump and pulling the fan shroud is all there is to it.
