C code help.
Old Oct 7, 2012 | 06:44 PM
sdam87's Avatar
sdam87
Default C code help.
So! Found out about the sweet gauge trick last night, did it today and a bunch of c codes pop'd up. Surfed here and figured out one of the c codes, but I cant find any thing on C-26, C-A4. Found out something is goin on with the drivers door lock (C-64). Im stumped... truck has a miss fire to it too so im hoping one of the other two will explain something. But 10-1 its just a crappy o ring on one of the injectors. I'm stumped. 02 ram with the 360, auto, 4 wheel squeel.
Old Oct 7, 2012 | 07:27 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You can (and should for future references) download the Service Manual for the truck and look through the Instrument Cluster section for those codes. Check the links in my sig
Old Oct 7, 2012 | 07:47 PM
sdam87's Avatar
sdam87
I'll scope it out. Thanks yo.
Old Oct 7, 2012 | 07:57 PM
sdam87's Avatar
sdam87
So. C-26 is illumnation output circuit shorted/open... C-A4 is Ignition run/start circuit rationality check. Are these major issues?? The check engine light is on cause my ac condenser fan is seized up.. Would that have anything to do with any of these?
Old Oct 12, 2012 | 01:37 PM
sdam87's Avatar
sdam87
Old Oct 12, 2012 | 01:41 PM
willdikem66's Avatar
willdikem66
Check your CEL codes that may tell you what the Misfire is, i doubt a C- Code is a part of it
Old Oct 12, 2012 | 01:46 PM
SLT8's Avatar
SLT8
open circuit c-26 could be from dome and interior lights being on when doing the key trick. Was your interior/dome lights on or the door open when you performed it? The A4 code description sounds like the start cycles of the key. Did you do the key trick more than once?
Old Oct 12, 2012 | 01:52 PM
sdam87's Avatar
sdam87
My check engine light dosent like to come on.. flicks on when i plug the ac condenser fan back in, (fan motor is seized) I'll make a vid tonight of what it dose and put it on here.
Old Oct 12, 2012 | 01:53 PM
willdikem66
Do the "Key Trick" any way you may have stored codes that dont show.
Old Oct 12, 2012 | 01:54 PM
sdam87's Avatar
sdam87
I think my raido was on... I'll do it again for ****s and giggles with everything off and see what pop's up.
