lowered 2006 Ram Camber kit?
Old Oct 10, 2012 | 09:06 PM
badblackram06's Avatar
badblackram06
Default lowered 2006 Ram Camber kit?
Ok heres the deal. I've had my truck lowered for around 4 years. Its a 2/5 kit. With lowering coils and not the drop spindles. Today i got new tires and an alignment because the outsides of the tires were starting to wear. Well after they were done they suggested a camber kit because they couldn't get it aligned perfect. They said get a camber kit and they will realign it. They didnt know what exactly i needed but they knew i needed one. So i kind of was like ok thanks i guess.. They were closing when i picked it up so my guess they didnt have time to look for one.
When i first lowered the truck they called and said i needed a $200 camber kit but found i had an 2006 model which already has adjustable lower cambers. Has anyone ever encountered this. What type of kit do i need? I've seen the press-in kind that presses into the control arm and the kind you bolt to the control arm mount points. I've never fooled with alignments so i'm in the dark here.
Thanks
Old Oct 12, 2012 | 09:04 PM
sabin420's Avatar
sabin420
You have to be at maximum adjustment on the top control arm to need one for the lower. Only thing I can think of is one that will need to be pressed in seeing as a smaller diameter bolt will have to be used going through the lower control arm to frame mounting.
