Old Aug 10, 2015, 02:38 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
Ignition Switch Problem
Old Oct 12, 2012 | 11:52 PM
bobinyelm's Avatar
bobinyelm
Default Ignition Switch Problem
Suddenly my '03 ignition switch will no longer move to the Accessory Position.
It WILL start to move toward Accessory, but just a TAD. Far enough to actually switch the accessories ON, but not nearly far enough to move toward the detent. The switch is released, it immediately snaps back to the "OFF, Remove Key Position."
The key EASILY turns to the right of OFF to "Off, but steering unlocked," "ON," and to the "Start" positions normally.
It's just like a mechanical "stop" that prevents the Accessory position from being engaged.
Is there a way to access the switch to possibly repair it, and if not, is the switch replaceable without having to get a new tumbler with new keys (which are not cheap, of course)?
I can live without the Accessory function, but has anyone else experienced this malfunction, and then had the switch fail to where the OTHER positions become inoperative? I'd hate to get stranded somewhere if this is the prelude to a failure making the vehicle unusable.
Thanks-
Old Oct 13, 2012 | 11:49 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
A new switch is fairly cheap and very easy to replace. Get them at a local auto parts store and search the site here for threads on how to replace or download the service manual from the links in my signature
Old Oct 13, 2012 | 12:01 PM
bobinyelm's Avatar
bobinyelm
So it is probably JUST the switch itself since the key WILL access the OTHER switch positions OK?
So I don't need a new "lock" portion of the pair, JUST the switch itself that plugs ONTO the lock portion, and it sounds like
that can be easily accessed and replaced?
I was afraid that I'd have to drill out "one-way" screws or something (to remove my steering column key-lock and replace thee lock tumbler AND the actual electrical switch the key turns).
Thanks!
Old Oct 13, 2012 | 03:28 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Dont quote me on it but I think it is something like 3 screws are needed to be removed to get it out and back in. Ask DirtyDog or do a search here on the site.
